Tigre Bluehead question
Is there a source for replacement rings for an old ST .60 Bluehead ?
Thanks Tommy |
RE: Tigre Bluehead question
We're sorry, but the SuperTigre G60 Bluehead was made so long ago that parts specific to it are no longer available. We'd not know if any current parts will work in that engine.
Well excuse me. Since the e-mail address in the other columns answer doesn't work
I thought you might know someone else. Sorry I bothered you. tommy s |
Bax, is there still a manual or a parts list aval. for download that you know off.
thanks |
The manual for the current .60-size engine will do, although the carb is slightly different...use the same procedure, but the high-speed needle will need to be opened 4-5 turns initially. As far as parts go, we don't have one, no. When we inherited SuperTigre from World Engines in the 1980's, the engine had been long discontinued, and parts lists/literature just wasn't there anymore.
