RCU Forums
-   SuperTigre Engines Support (https://www.rcuniverse.com/forum/supertigre-engines-support-163/)
-   -   G75 Top Flight Header (https://www.rcuniverse.com/forum/supertigre-engines-support-163/2594875-g75-top-flight-header.html)
MMallory 01-28-2005 04:28 PM
Help!! Can anyone help me find 2 TopFlight in-cowl headers. Tower has them on back order and does not have an expected due date.
Thank you,
Mark M.
Bax 01-28-2005 04:55 PM
RE: G75 Top Flight Header
Here's the part you need:
TOPQ7925 EXHAUST HEADER ST .61-.75 $19.99
This can be ordered for your SuperTigre G-75 from any hobby retailer who sells SuperTigre engines and accessories.
captinjohn 01-28-2005 10:31 PM
The question was can anyone help....if you do not want anyone to chime in do not send these posts. Thanks Capt,n
MMallory 01-29-2005 10:09 AM
Bill,
Actually, I need item number TOPQ7926 for the G75. I can't find this anywhere, all of the stores say it is backordered.
Mark
Bax 01-31-2005 12:04 PM
Use the number I gave you. It's the correct one. The one you mention has been discontinued because it duplicates the one I gave you.
MMallory 01-31-2005 04:10 PM
Great! I will order right away.
Thanks for the follow up. I wish Tower knew their inventory this well.
MMallory 02-10-2005 07:36 PM
Bill,
I took your advice and ordered two, the headers doen't have bolts long enough to attach them. Can you help me get the bolts?
Mark
hattend 02-10-2005 08:01 PM
Mark,
If you still have it, look in your owner's manual. It should have a parts breakdown/blowup view and it will tell you the bolt you need. Then just order it either from Tower or Microfasteners (if you want a bunch of them)
Don
Bill DCat 03-11-2005 06:02 PM
Mark,
I believe the bolts that come with the G75 engine will work with that header. If you're not working with a new engine or don't have the bolts that came with it - disregard this...
Bill DCat
MMallory 03-11-2005 07:05 PM
Bill,
I have 2 brand new engines. The bolts that come with the engine are the same size. The problem is the header has one bolt that completely passes through it. This bolt is much longer and since nobody has them, I decided to return these mufflers and use the Slimline pitts style.
Mark
