RCU Forums
-   SuperTigre Engines Support (https://www.rcuniverse.com/forum/supertigre-engines-support-163/)
-   -   Will Muffler Choice Affect Break-In? (https://www.rcuniverse.com/forum/supertigre-engines-support-163/3211575-will-muffler-choice-affect-break.html)
sgillmore 07-29-2005 09:50 AM
I'm getting ready to break-in a new ST G-51. I have a Macs one-piece muffler that I plan to use with this engine. Here's the question:
Which muffler should I use during the break-in period--stock or Macs?
I got to wondering, should I use the stock muffler until the engine is properly broken-in, then switch to the Macs? Maybe it's better to start out with the muffler I plan to actually use (Macs)? Does it matter?
SG
Bax 07-29-2005 09:56 AM
RE: Will Muffler Choice Affect Break-In?
Actually, as long as the muffler's properly-sized for the engine, you can use any brand/type for breakin. It's not that critical as long as the engine will run well and not overheat due to a too-restrictive muffler. If it's easier to use the Mac's, then use it.
sgillmore 07-29-2005 10:27 AM
Thanks for the info and quick response!
