RCU Forums
-   SuperTigre Engines Support (https://www.rcuniverse.com/forum/supertigre-engines-support-163/)
-   -   ST Compression (https://www.rcuniverse.com/forum/supertigre-engines-support-163/3829639-st-compression.html)
HD21A 01-26-2006 09:29 PM
ST Compression
Bax Reference my post on 1/17/2006, I receive another new ST 2300 from Tower today which is for another big plane, put a prop on it and a few drops of after run on the piston and it has wonderful compression like my ST3000. I have put about 2 gallons thru the first ST 2300 and it has about 30% compression of the new one. Would like to send it back to have you look at it. Was purchased 12 /10/2004 from Tower and just started to break it in this month. Have a printable copy of the Tower order confirmation but not the original billing invoice to enclose with it. Bob Ohio
HD21A 01-27-2006 10:05 AM
RE: ST Compression
Bax In looking at the weak 2300 as compared to the new one, the ring appears to be stuck in the piston. It was that way when I got it . Bob Ohio
Bax 01-27-2006 11:43 AM
RE: ST Compression
Send it in, by all means. We'll be glad to look at it and get it right for you.
