S-90K Question... Backplates!
Bax,
I just got a new to me low time S-90K, and the backplate on it has been tapped for crankcase pressure, presumably to run a pump. My installation will not require a pump, so I need a backplate that has not been tapped. Will a backplate for a G90 fit the crankcase of the S-90K? I know they are different part numbers (I've been searching all night so far) but I can't find any info on this otherwise. If the only difference between the 2 part numbers is "CHINA" stamped on the back, I'm fine with that. The dimensions are what's important. Your help will be greatly appreciated!! Thanks, |
RE: S-90K Question... Backplates!
The current G-90 rear cover will fit onto the S-90K engine.
Bax,
Thanks for checking on that for me, I really appreciate it ! Brian |
| All times are GMT -8. The time now is 04:37 PM. |
