Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 No flat spot on motor shaft ?? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 09-14-2010, 05:13 PM
My Feedback: (15)
Default No flat spot on motor shaft ??
Hi,
I would like to put the pinion on my T-rex 450 motor shaft, but do I need to file a flat spot on the motor shaft to grab the set screw ?
Thanks for any help !
Terry
Old 09-15-2010, 04:40 AM
soneebee's Avatar
Default RE: No flat spot on motor shaft ??
best that you do.. as to make sure the pinion will not slip... I had a motor before that did not have the flat spot.. after sometime of flight i had to do an autorotation as heli lost power.. all because the motor pinion slipped
Old 09-15-2010, 08:57 AM
BarracudaHockey's Avatar
You can, you can also put a little green locktite between the pinion and shaft. I prefer to grind a flat spot.
Old 09-15-2010, 07:18 PM
My Feedback: (15)
Thanks guys,
You have been a big help !!
Terry
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
