Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Dirty on tail shaft >
Dirty on tail shaft
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Dirty on tail shaft
Old 09-17-2010, 10:35 AM
Default Dirty on tail shaft
Hello,
I have a clone of a Trex 450 and I have had problems in ocassions with the tail because I fly it on a sand field (without no grass) and with several flights the tail shaft begin to get a black dirty.
In order to get the tail movement smooth, it is necessary to clean this shaft with alcohol, but is really tedious so I wonder if there is some kind of oil or any other thing that could prevent this part of the heli to get dirty so it is not necessary to get cleaned from time to time.
Regards.
Old 09-17-2010, 11:52 AM
Default RE: Dirty on tail shaft
In all my flying sessions with crashes, dirt, sand, dust  not once has my 450's tail stuck or binded because of dirt on the tail shaft.  I just put a drop of triflow once in while and i'm good.  if your tail is holding fine , try not to worry so much on this one.</p>
Old 09-17-2010, 11:59 AM
Well, I worry about that because in ocassions my tail is not going good and the gyro is not able to fix it, so I have needed to clean the tail in order to get working ok again, hehe.
By the way, what is triflow? I don't know that product.
Thanks in advance.
Old 09-17-2010, 12:03 PM
this is triflow:
http://www.amazon.com/Flow-Teflon-Bi.../dp/B0002ITTK2
its a light oil.  works wonders!
Old 09-17-2010, 01:29 PM
I use either Triflow or White lighting MTB ( Mtn Bike Lube ) Get it on line or in any quality Bike store Teflon impregnated sinthetic self cleaning lube see attached
http://www.nashbar.com/bikes/TopCate...12_-1_200278_N
jimmy R
Old 09-17-2010, 01:32 PM
And what is better? Triflow or MTB?
And thanks a lot both.
Old 09-17-2010, 07:51 PM
Cleared2Engage's Avatar
Tri-Flow is better. White lightning (at least the stuff I used to use on my bike) leaves a kind of wax behind.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
