Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 HELP!! tail moving slowly >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 09-21-2010, 07:46 PM
Default HELP!! tail moving slowly
it on a 450t clone using a wfly radio hitec 81on tail a wk-g006 gyro and 3 hs65hb on head a 3500kv motor and a 25amp electafly esc and a 2200mah 20c lipo
when i get it in a hover and try to spin tail one way or the other it moves slowly, im not good enough to keep it going on around that slow
is there something i can do or change
i know the radio, im saving for another spectrm 6200 receiver in time i'll get it
Old 09-21-2010, 08:26 PM
Default RE: HELP!! tail moving slowly
Have you checked the travel of the tail servo when you move the rudder stick? You should be able to reach both extremities without going beyond. Check the gyro setting for travel.
Old 09-22-2010, 06:26 AM
it goes full both ways but slowly i have changed the servo twice and still the same. the gyro does not have a limit just a gain
Old 09-22-2010, 02:52 PM
Iam not familiar with the radio but can you adjust the endpoints for the rudder channel? If so increase them, if everything else is setup right, this is how you control piro rate.
Old 09-23-2010, 12:55 PM
i found a manual on the radio but dont understand it im going to try to post it if it works can some one tell me if it can be
File Type: pdf
Old 09-23-2010, 11:53 PM
I don't think you will be able to adjust your piro rate on this radio unfortunately.
Old 10-12-2010, 02:11 PM
Thanks for the help , I went and got another receiver for my dx6i Nd a .06 speedy tail servo and a align 500x gyro
And it's all good now...
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
