Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Why do I have 5 amps at idle? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-18-2010, 06:23 PM
Default Why do I have 5 amps at idle?
I recently crashed my T rex 450. The motor seemed to have thrown a magnet and froze. I replaced the motor, and it is tight when trying to turn it by hand or by turning the gear. I have adjusted the clearance between the gears, and it doesn't have any affect. I have noticed that some of the larger motors have a similar difficulty, and blame it on the stronger magnets etc. I hooked my whatt meter and have about 5 amps when I first hooked it up until I add power, and the current drops to .1 amps and gradually climbs. The battery that was in the crash has been replaced with one that is good ( and tested in an airplane ). Is this normal. Should I replace my speed controller? I hate to just start replacing things if it aint broke!
Old 11-04-2010, 01:20 PM
Default RE: Why do I have 5 amps at idle?
make sure that your motor brake function is not enabled... otherwise i think your ESC may have been damaged.
Old 11-04-2010, 03:28 PM
I have an align ESC, how do I enter programming mode?
Old 11-04-2010, 06:00 PM
Have a look in the Trex manual. It should be described there. (It was in my Trex 450 Sport Super Combo).
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
