T-Rex heli For all you T-Rex lovers out there, this where you can post!
250 tail wag
Old 10-30-2010, 03:08 PM
Default 250 tail wag
Wow didn't realize it didnt come thru on the post sorry
what I was asking if you could put some expo into the tail to soften the center response down just a tad to see if it would make the tail behave a little better while in a hover mode without the wagging back and forth
but it sounds like the tail will just be an nuisance in waggin
any thought's on the expo
Old 11-01-2010, 10:20 PM
Cleared2Engage's Avatar
Default RE: 250 tail wag
Just check the gain on the widget. That'll fix it.
Old 11-02-2010, 08:03 AM
The original message is not displaying, If your still having an issue please re-post, so others can respond & try & help you out.
The little buggers are prone to tail wag issues, so if its NOT a simple gain fix, either myself or others will need to know exactly what it's doing, & what you've done so far in order to try & point you in the right direction
I've had several issues with mine that I've had to resolve. So far one involved a tail modification to the blade grips to remove the slop. easy mod & cheap also.
Old 11-03-2010, 04:00 AM
soneebee's Avatar
the 250 heli is really like that.. it had tail issues from the very first time it came out.. this is why align did some modification and revision on the tail design of the later helis.. but its still has the little quirks..you will just have to check the bearings... it somewhat causes binding which in return creates bad wagging
Old 11-11-2010, 11:13 AM
Anyone have a advice about expo use on tail
Old 11-11-2010, 12:16 PM
That depends on what you like. Myself I have -10% dialed in to speed it up a bit. But that's my preferance. If it seems to fast add + expo to slow it down if too slow add - expo to speed it up a bit. Just try small increments at a time until you get it where you want.
Old 11-17-2010, 02:38 AM
that's kinda what I was thinking could be done thankyou
Old 11-18-2010, 12:03 PM
I have a Etech G106 gyro ($25 on ebay) and JR ds290g Tail servo on mine. No wag, no drift on punchouts.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
