Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 450GT and 450 pro TT tail booms >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 12-08-2010, 04:11 PM
Default 450GT and 450 pro TT tail booms
I have the chance of getting some new Align 450se tail tubes i was wondering if they could be used on my HK 450 pro TT , will the centre shaft support fit in the tube ,are they the same size, are the ends differant etc ( i should have looked before i built my TT )
phil.
Old 12-08-2010, 04:23 PM
Rob2160's Avatar
Default RE: 450GT and 450 pro TT tail booms
ORIGINAL: madphil
phil.
I just looked at the tail boom from the HK 450 GT and it is different to the Pro boom.. it does not have the locating hole on the read of the boom.
Not sure about the 450 SE boom
Old 12-08-2010, 04:28 PM
Thanks Rob ,are they the same lengh ,
do you think you could get away with drilling a locating hole if everything else is the same .
Old 12-08-2010, 06:28 PM
Rob2160's Avatar
ORIGINAL: madphil
Hi again,
yes they are exactly the same length..
I also looked at the tail boom from the HK 450 - This one http://hobbyking.com/hobbyking/store...dProduct=11446
and it is identical to the Pro 450 TT boom.. it has the hole..
The 450 GT tail boom is the same length also but is missing the hole..
You may be lucky and the ones you are looking at may have the hole..
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
