Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Cx 450SE V2 tail rudder stopped working. any ideas? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-24-2011, 09:14 AM
Default Cx 450SE V2 tail rudder stopped working. any ideas?
Took out my CX today, as usual inspected it visually, set all controls on the tx to neutral ositions and connected up the battery. Gyro initialised and i spooled her up, heli span out of control, yaw input didn't help at all, shut her off... checked the tail rudder and no movement! last time i turned off the heli there was no problem, norma flight, no errors, landed. It's the standard RTF gyro/servo's for now. If it is any help the gro has a constant red light when it is set, and it flashes when i use the yaw controls. Also i don't believe it is a tx/rx problem as the tail doesn't move when i wag the heli, in fact the servo isn't even recieving power. Any thoughts? Thanks!
Old 01-24-2011, 09:38 AM
Default RE: Cx 450SE V2 tail rudder stopped working. any ideas?
Sounds like a Gyro problem to me. What type is it? Is it connected properly in the Receiver? The Tail Servo connected properly to the Gyro?
Old 01-24-2011, 10:47 AM
ORIGINAL: gi1mo2
Thanks. It's a ****e copterx gyro, I'll go connect and re-connect everything after, and see if that helps. Can't wait to get a futaba gy401 and some good servo's
Old 01-27-2011, 11:02 AM
Turns out it was a servo problem. can't figure out what, motor is fine, connectons look fine, but its dead
Old 01-27-2011, 02:00 PM
Yep, connecting the tail servo directly to the receiver to bypass the gyro would have been a good test.
Old 01-27-2011, 03:29 PM
I connected it to a gyro on another choppah! There is a light on the gyro and it was flashing when i gave an input so i took it the gyro was giving commands to the servo so it made sense... thank god it didn't go mid flight :O
Cheers for the help!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
