Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 How do you spool up your 600 >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 03-08-2011, 04:57 PM
My Feedback: (12)
Default How do you spool up your 600
I have been having a bit of a time with that. Sometimes if I'm steady I can spool it up without it jumping around. I do find if it starts to jump that if I cut the throttle and give it a quick shot it straightens out. I would like a sure fire way to spool up without the problem of vibration on startup.
Old 03-10-2011, 02:32 PM
Default RE: How do you spool up your 600
First make sure the blades are as straight as you can get them. Spool up slow and smooth. I never have any significant vibration.
If you're starting with the blades straight and still having a lot of vibration, I'd guess either your blade grips are too loose or too tight or something is bent.
Old 03-10-2011, 09:05 PM
Or unbalance blade, or tracking could be out.
Old 03-14-2011, 12:29 AM
If you are running electric, you may not have your ESC set up for soft start. If your blades jump at start up, you could end up with a blade strike on your boom.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
