Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 450 Pro tail rotor drive gear replacement >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 03-14-2011, 04:32 PM
Default 450 Pro tail rotor drive gear replacement
Dinged the tail and stripped the torque tube front drive gear. I have it disassembled, but how do you remove the gear from the drive assembly to replace it? I have the replacement gear in hand, but the manual says that assembly is factory assembled. What's the trick to removing it? Thanks.
Old 03-15-2011, 11:33 AM
Default RE: 450 Pro tail rotor drive gear replacement
If it is the one that directly connects to the torque tube, remove 4 screws and pull the whole assy out.  Once you do that, the 2 halves can be separated and change the gear(s).
Old 03-15-2011, 12:45 PM
Thanks...I figured that out after I got it out and looked close. Since the manual says it's factory assembled, I didn't realize that it split in half. Got it fixed and back in action.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
