Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 5 Blade rotor and 3 axis gyro???? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 03-17-2011, 04:45 PM
jesses151's Avatar
Default 5 Blade rotor and 3 axis gyro????
<div id="post_message_17709333">Maybe there's already a thread out there about this but I'm having trouble finding it. I want to take a 450 sized heli and go flybarless with a <span class="highlight"><font color="#ff0000">5</font></span> <span class="highlight"><font color="#ff0000">blade</font></span> <span class="highlight"><font color="#ff0000">rotor</font></span> head and a 3 axis gyro system. The intent is to build a Hughes 500/530 that is fairly scale looking. I know I could spend top dollar and get the best but I'd rather use this forum to find out about the less expensive products that get me the same results. Any feedback is appreciated.
-Jesse</div><! / message >
Old 03-17-2011, 04:49 PM
BarracudaHockey's Avatar
Default RE: 5 Blade rotor and 3 axis gyro????
Beast from Horizon or HeliCommand HC3-X or VBar
Old 03-17-2011, 09:00 PM
I have this Hughes HD500 body on my HK450.
http://www.hobbyking.com/hobbyking/s...dProduct=10112
You could use this 5 blade head - cheap:
http://www.hobbyking.com/hobbyking/s...dProduct=12612
According to discussion, no special gyro required.
Old 03-18-2011, 02:04 AM
jesses151's Avatar
As far as the "no special gyro required" does anyone have experience with flying a flybarless heli without one? Also I've seen the HK 5 blade head and was considering it. Is there any problems from these?
-Jesse</p>
Old 03-18-2011, 05:29 AM
If you look in the discussions around that head, there are a few recommendations on gyros. Seems that unless it is very well setup, you might have some issues without some electronics...
Old 03-18-2011, 09:18 AM
It "can be done" with proper setup and blade choice (heavy) but it can still be a handful.
Old 03-19-2011, 12:17 PM
I am running a 4 blade head on my EC135 with the helicommand system that takes away the gyro and controls the rudder aswell ,
should work with 5 blades on your MD500
phil.
ID:	1580991   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
