Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
FS-TH9X Aileron/Elevator stick not responding
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 07-02-2013, 09:02 AM
Charl450_RSA
Default FS-TH9X Aileron/Elevator stick not responding
Hi Guys
I have recently made the jump from 4 channel co-axial to 6 channel variable pitch.
I bought a HK450 and Fly Sky FS-TH9X transmitter from a trusted friend (second hand)
Everything worked perfectly until I replaced a stripped servo over the weekend.
The transmitter does not pick up any stick movement from my aileron/elevator stick.
I am running the following settings:
Type: Heli3-1
Modevat: PPM
Stick Setup: Mode 2
The servos are working when I change settings but not responding to the transmitter stick movement, when I go into the menu under the display option where it shows the positive and negative movement on the sticks I only get Throttle and Rudder movement.
If anyone could please assist me in correcting this problem, as a newbie to 6 channel I am very anxious to get flying again.
Thank you in advance
Old 07-25-2013, 12:14 AM
BubbasanJohn
BubbasanJohn's Avatar
Default RE: FS-TH9X Aileron/Elevator stick not responding
Where is the friend that sold this stuff to you?   Only prob with buying stuff that is not commonly flown at your field is there is no one that has experience with your brands.  I have no idea how to operate the programming of  the tx you have.
Remove the new servo and see if controls return.  Could be a bum servo?  Do you have access to a different rx?
