Tail rotor suddenly not working after 6 month storage
Good evening all. After being in storage for several months, I pulled out my 450 trex to give it a whirl. Everything is working fine except the tail rotor isn't spinning. Prior to storage, it flew fine. I thought it was the 401 gyro, so I got a used one from Ebay. Still nothing. What else can I check and how?
Check the belt maybe loose or a bad tail shaft pulley (pulley slip from the shaft) or maybe the
main gear screw missing (screw holding the main gear to main shaft)
