Trex 450 Sport throttle/pitch curve help
NJ
Hi all,
I'm transitioning from a FP heli to my first CP, on a Trex 450 Sport.
What would be a good throttle/pitch curve to start out on? Looking to make a smooth transition into CP.
I'm not interested in 3D flying, will ultimately be flying scale.
Thank you in advance for your help.
I'm not familiar how to set JR radio also you also need pitch gauge to set your pitch curve.
ex setting pitch curve.......................T up 0/50/100
T hold 43/53/100 ( for flight forwad)
other RCU member could help you.
MN
If you have the manual it will give you a good general flight tc/pc which is usually fairly tame for a novice pilot. but typically -2, 5, 12 for the pitch curve and for throttle I use a generic throttle curve that the radio starts off with.
