Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
T-Rex 450 XL... Good deal or not?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 02-23-2006, 02:22 PM
jeffdom1978
Default T-Rex 450 XL... Good deal or not?
I am interested in picking up a T-Rex 450 XL from someone. I am still a begginer and have a CP2 currently. I need a good heli that I can fly outside. I live within walking distance of many parks and fields.
I am interested in buying a T-rex to use in spring after i get good enough on my little honeybee Cp2.
Here is the package for the Trex I am considering:
. FUTABA T6EXHP COMPUTERIZED PCM 1024 TRANSMITTER RADIO W/RECHARGEABLE BATTERY PACK.
2.HITEC ELECTRON 6 RECEIVER
3. ALIGN 400L 2500KV BRUSHLESS MOTOR WITH HEATSINK
4.ALIGN 35 AMP SPEED CONTROL ESC.
5.ALIGN HEADING HOLD GYRO
6.ALL HEAD SERVOS- HITEC HS56HB
7 TAIL SERVO - HITEC HS50 HIGH SPEED
8.ALUMINIUM ROTOR HEAD AND BUTTON
9.ALUMINIUM MAIN BLADE GRIPS
It is already pre-built and ready to fly.
All this for around $450
I guess it is almost brand new.
Should I get this or wait and get a SE? I'm not too sure on all the differences anyways.
Thanks for any input!
Old 02-23-2006, 03:08 PM
Motions
Motions's Avatar
Default RE: T-Rex 450 XL... Good deal or not?
This is a very good deal. Is this new or used?
If your moving up from a CP2, there is absolutely no reason to get the SE. It's just a XL blinged out with metal parts. The stock XL is a great heli and will last you a while with all stock parts. It looks like there are already some metal parts with it so your doing better than stock already.
Old 02-23-2006, 06:19 PM
cptsnoopy
if all the parts are in good condition you may have to fend others off trying to get a deal that good. The only weak points are the motor and the gyro. the heli should still fly fine using the ones included, they can be upgraded at a later date if you want more performance.
Old 02-23-2006, 07:49 PM
jeffdom1978
yea, already gone
5 minutes too late
oh well. thanks for the responses!!
Old 02-23-2006, 08:05 PM
jeffdom1978
Ok, how about this setup for $600 including radio... All perfect condition and trimmed.
This is a complete 3D Heli with everyting you need included, only ran 1 battery through it after getting it tuned, it has never been crashed, it is in perfect shape....
A perfectly setup / built Trex 450XL CDE with Brushless Motor and all electronics. complete package !!! The Helicopter ships as you see it in the picture. This package comes with high end electronics such as a heading lock TLB Gyro, Lithium battery and charger, Hitech Micro Servos and everything is connected and ready for you. So if you want to get into this amazing Helicopter without spending the time to build it and set it up, this is the ticket !!!
Includes.
**Complete Align Trex CCPM Heli with Upgrades.
**Mega Brushless Electric Motor with cooling plate.
**All Servos Replaced with HS-56HB Feather Micro with Karbonite Gear Train.
**Hitech Electron Micro Receiver with Crystal.
**Upgrade Speed Controller JETI Advance 30 plus.
**Blue Align metal tail drive.
**All of the OEM parts that I took off for upgrades included, even the stock servos and align speed controller.
**Three 3-cell 11.1volt Li-Po batteries, two of which are new, neve used.
**KS Pro Digital DC Li-Po Charger\Discharger, charges all Li-po's, Ni-Cad\Ni-MH.
**Three sets of Align 335 HS1053 Rotor Blades.
**Two Picth Gauges and Blade Balancer.
**Extra Rear Tube and Tail Rotor Blades.
**Includes the HiTech Eclipse 7 QPCM Transmitter with the Spectra Synthesizer Module, lets you select any channel with out crystals.
**Carbon Fiber Training Gear.
**All Manuals included.
Old 04-04-2006, 09:05 PM
electron
electron's Avatar
Tell me is this a good deal for 250.00
Includes:
T-REX 450X Helicopter
ALIGN MOTOR 2500kv...
25A Speed Controller
3 Hitec Servos HS-56 BB
1 Futaba S3103 for the Tail
401 Futaba Gyro
Alum CNC Fly Bar System Blue Upgrade
Alum CNC Swash Plate Blue Upgrade
Alum CNC Bar Control Rods Blue Upgrade
Old 04-04-2006, 09:27 PM
H0ndaJunkie
Here's what I'm selling on eBay currently:
* Fully built T-Rex 450XL CDE (CCPM)
* Align 25A Electronic Brushless Speed Controller, with BEC and soft-start
* Align 3550kv 430L Outrunner Brushless motor
* 3 x Hitec HS-55 Servos
* 1 Hitec HS-50 servo for high speed tail control
* Futaba GY401 AVCS Heading Hold Gyro
* Hitec Electron 6, 6 channel FM Receiver (No Crystal)
* Align Blue and silver aluminum Swashplate
* Aluminum FlyBar center with Ball Bearings.
* Align Aluminum motor Heatsink
* Blue Aluminum Battery extension bracket
* Align upgraded Stainless Steel Ball set
* Blue aluminum Tail Servo mount
* Deans 2 piece Base Load Whip Antenna
* Male Deans connector installed on ESC
* 1 x 21mm Ferrite Core Ring installed on ESC-to-Reciever wire.
* 1 x Xtremepower 1800mah 11.1v 12C Lithium Polymer (LiPo) Battery with installed Deans female connector
* 1 set of 325mm Carbon main blades (Yellow)
* 1 set of 515mm white wooden main blades
* Owner's Manual for the Heli, ESC and Gyro.
[link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=6049247296&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=6049247296&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1[/link]
I've set the reserve at $700.00......I'm open to offers though.
