Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
CAN I USE HS-65HB as tail servo for my Trex?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 02-24-2006, 04:49 PM
dhotamis
Default CAN I USE HS-65HB as tail servo for my Trex?
I am not looking for a very expensive servo right now. I am a beginner so I want something that will work the tail but also not more than $30.
Thank you all
Deniz
Old 02-28-2006, 02:55 PM
dajensen
dajensen's Avatar
Default RE: CAN I USE HS-65HB as tail servo for my Trex?
I am using a Futaba 3110 exellent speed .1 sec -60deg trav, good torque 22 in/oz and low cost $27.
Old 02-28-2006, 10:02 PM
jeepson33s
take a look at the hitec ones too they have a good selection and mutiple apps
Old 03-01-2006, 12:29 AM
Misspeld
I'm useing the HS-56HB for a tail servo with the Align gyro. It works fine for me. I'm like you in that I'm still learning so I can't say how this setup would work for 3D, but for 9 flights now I've had no trouble.
Old 03-02-2006, 08:40 PM
dhotamis
I have the align gyro too, thank you all for the comments.
How does your gyro work. It sounds like good so far.
I just build my Trex. Can you send me some pictures of your t-rex please? [email protected]
Thank you
Old 03-03-2006, 10:49 AM
chipperg
My Feedback: (9)
The 56 will not hold the tail for 3d but it is great for learning.
Old 03-03-2006, 01:56 PM
Dragonuv
Try HS-81.. much better tail servo than 56 and 65 but slightly bigger in size
Old 03-03-2006, 03:42 PM
VinceHerman
VinceHerman's Avatar
I thought that the HS56 was the standard servo to use on the tail. The 65 is slower, so I do not thing it would be desireable.
Vince
Old 03-03-2006, 06:29 PM
Misspeld
ORIGINAL: dhotamis
Thank you
dhotamis,
I'm still learning about the gain. so far I can't tell the differance between normal and heading lock, but I've only hovered it indoors.
I did spin it around in a hover (I don't know if that qualifys as a piroet or not) and it seemed to work fine. I can't really say how good this setup is since I don't have any thing to compare it to exept the blade CP I used to have. Any way, heres some pics.
ID:	419459   Click image for larger version
ID:	419460   Click image for larger version
ID:	419461   Click image for larger version
