Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Just built my Trex and need to know....
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 02-26-2006, 12:06 AM
Misspeld
Default Just built my Trex and need to know....
First, do any of you use the GWS R-6NII on your trex and if so were do you plug in the ESC to the reciever. The trex book says ch 1 and the reciever says ch 4. I've got a JR 8103 TX. I don't have my gyro yet but wanted to set up the head.
Second, should I use the rubber mounts for the DS281 servos or hard mount them to the frame.
This is a trex 450XL but I bought the SE frame and built it with that so that I could up grade every thing else as I replace parts.
Dave
ID:	415736   Click image for larger version
Old 02-26-2006, 09:32 AM
exeter_acres
exeter_acres's Avatar
Default RE: Just built my Trex and need to know....
I would not trust that rx. there is just too much RFI on a Heli.... for JR, something like the 770 would be a very nice way to go....
as for the servos... hard mount them... and they will be fine for hovering a basic flight... but the gears will strip when you try to 3D them...
invest in the metal gears for the servos...
I believe ch 1 is throttle ch for JR (I fly Futaba and our throttle channel is 3) either way, plug the ESC in to the throttle channel
Old 02-26-2006, 12:44 PM
WhtBronco
WhtBronco's Avatar
I went with the JR 770 Rx and suggest you look into it as well.
Yeap, hard mount the servos. There's way to much flex with the grommets on these helis.
I have the 281 servos as well and have thought about the metal gears, course they'll add 1.5oz to the heli.
FWIW, I have not yet flown my Rex, it's almost done. I have flown my buddies 450X a good bit, though.
Old 02-26-2006, 01:46 PM
cptsnoopy
the jr rx is good but I have actually had better luck with the hitech electron6. in my bird i got better range and less glitches. each users experience can and will vary so it is not a hard and fast rule. I have used those gws rx's (i have 4 sitting in the hobby room collecting dust) I have had nothing but bad luck with them.
Old 02-28-2006, 01:52 AM
Misspeld
Thanks all of you for the feedback. I did hard mount the servos. I use GWS recivers on my combat planes with good
results and I had it so I thought I'd try it. I flew it today twice so far,(the batts. charging now. I got two twiches of the tail so far,
so I'll be getting a better reciever tomorrow. If I get to were I can do 3D, I'll put better servos in then. I mostly got this to fly indoors
when the weather stinks, otherwise I'm out flying 3D or combat with fixed wings.
Thanks again,
Dave
Old 02-28-2006, 10:33 AM
WhtBronco
WhtBronco's Avatar
I'm not sure you'll find better servos for the Rex. All the popular ones seem to have the same issue with gears from what I have seen.
FWIW, Ray and Kyle Stacy fly the DS281 servos in both of their T-Rex's. Ray stated he has a drawer full of other micro servos he tried and found the 281's to be the best for consistent centering.
Old 03-01-2006, 12:22 AM
Misspeld
Whtbronco,
Thats good to here. I flew it four more times today and all went well. I bent the antena tube in to a half circle around the landing gear so the antena would never be pointed straight at the RX and no more glithes. Here is a picture just cause there's not enough pictures around here.
Old 03-01-2006, 09:43 AM
WhtBronco
WhtBronco's Avatar
That's an interesting way to route the antenna. If it means no more glitches than it's perfect right!
I ran mine from the Rx to the tail and back to the front. I just don't like using whip antennas even though they look better and are much easier to route of course.
Old 03-01-2006, 10:45 AM
ckoelliker
I had a lot of glitching problems when setting up my trex. I have a hitec six channel receiver. Everyone told me it was either the receiver or the proximity of the receiver to the esc. After moving everything around with the same glitches, I just let my antenna hang from the helicopter. It flew great. After about five glitch free flights I installed a deans whip antenna and have not had a glitch since.
Old 03-01-2006, 10:47 AM
timothy thompson
hitec electron six good choice m,ake sure you get the correct shift for yout tx
Old 03-01-2006, 11:28 PM
tom_sandiego
tom_sandiego's Avatar
ORIGINAL: cptsnoopy
cptsnoopy,
What's the tx you use with the electron6? I'm trying to find informations how to setting up my airtronics rd6000 with that electron6 for my SE
Old 03-02-2006, 10:43 AM
jh4db536
is your electron6 the correct shift?? Airtronics are positive shift like JR.
also, electron6 are dual conversion Rx, do you have a matching Dual conversion xtal??
