T-Rex heli For all you T-Rex lovers out there, this where you can post!
T-rex
Old 02-27-2006, 08:57 PM
Shortymet55
Default T-rex
Im looking into a T-rex. I have a list of everything i want to get, so could you make usre everything is good and Im not forgeting something I need? And this is EVERYTHING, so if there are accesories i need please tell me.
-T-Rex 450SE Silver w/3550 KV Motor and 35 ESC and HeliHobby Deluxe Accessory Pack- $489.00
(accesory package includes:
- Micro Heli Pitch Gauge with engraved degree markings
- T-Rex 450X Aluminum Battery Extension Plate (Blue)
- Deans Mini Antenna 36 Inches (one piece)
- Tri-Flow Teflon Lube
- Double Sided Strong Tape
- Micro Ball Link Pliers / Tweezers)
Futaba 7CHP- $169.95
Futaba GY401 Gyro- $135.00
Hitec HS-56HB Karbonite Gear Sub Micro Servo U (3)- $71.97
Futaba S9650 Digital Mini Servo- $59.99
Mini R146iP PCM 72MHz Single Conversion Receiver- $74.99
Triton Lithium Computerized Charger- $124.00
Thunder Power3C LiPoly Pack 2100 mAh 11.1V- $75.95
Old 02-27-2006, 08:59 PM
Shortymet55
Default RE: T-rex
O I forgot and some Dean Plugs so I can solder tham onto the battery and ESC.
Old 02-27-2006, 10:22 PM
jh4db536
Default RE: T-rex
i suggest, changing the TP lipos for Apex MK3's. 1 battery definitely isnt fun. for the price of one TP pack, you could get almost 2 apex's and theyre almost the same in terms of performance.
btw, how far did you get with the BCP?
try the new hs65 servos on the cyclic. they cost about the same, but are a little beefier. they have the correct mounting positions too.
Old 02-28-2006, 06:57 AM
Shortymet55
Default RE: T-rex
I have a CP2, but close to the same thing anyways. Accually im not very far. I just hovering, but plan to go out for FFF soon. Then when i master that Im gonna get this T-rex. So im planning it all out now so i can get the money for the heli, then buy it, then have it built. Then after that Ill be finished up with the CP2 andready to move on.
Old 03-02-2006, 12:05 AM
hdoc
Default RE: T-rex
Wouldn't use the 56B servos--Need redrilling for mounting-- Suggest the futaba or I'm using MX 50's which have slightly more torque than the 56B's and fit in perfectly. The 9650 & GY401 is perfect. I prefer a dual conversion radio (I have the Hitec 'electra' I think.) Less chance of interference. Just finished mine 5 D ago and, though a novice Heli flier, have had nothing but great flights with this bird. it's a great machine.
Lloyd
Old 03-02-2006, 07:03 AM
Shortymet55
Default RE: T-rex
Do the HS-65's fit correctly?
Old 03-02-2006, 10:37 AM
jh4db536
Default RE: T-rex
yes, theyre like 56's that dont require modification to fit. a bit stronger, but not as fast; and therefore, not well suited as a tail servo - perfect for cyclic though.
if you still want to use a 56 on the tail, that's probably one of the best choice for a non digital servo.
Old 03-02-2006, 07:19 PM
Shortymet55
Default RE: T-rex
ok well im definetly useing a Futaba digital 9650 for tail so that wont matter.
Old 03-02-2006, 08:43 PM
hdoc
Default RE: T-rex
Not to be redundant, but the MPi MX-50HP's fit perfectly without modification & have greater torque & speed than the Hitec 56B's.
The 9650 is a 'monster', yet fits perfectly on the 'stock' tail boom servo holder.
Lloyd
