Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Glitchy servos on T-rex
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 03-19-2006, 09:41 PM
knotthrower
Default Glitchy servos on T-rex
Hi there,
Have noticed that servos on my T-Rex are very glitchy. I have a Futaba tx/servos with an FMA autopilot receiver/sensor. I have the ESC directly below the rx which is inside the airframe a few cm back from the motor. Could interference from the ESC be doing this?
Many thanks
Old 03-19-2006, 11:34 PM
jh4db536
Default RE: Glitchy servos on T-rex
#1 how is your antenna routed?
#2 is the xtal very secured?
Old 03-20-2006, 10:15 AM
BarracudaHockey
BarracudaHockey's Avatar
I'd move the esc to the side frame and nix the copilot and see what happens, if that fixes reconnect the copilot and check again.
Old 03-20-2006, 10:15 PM
hdoc
Agree with Barracuda--In addition the Ant & Radio should be at least 10 Cm from ESC & Motor. Does sound like interference.
Also be sure Metal head parts (ths SE) are tight (The top part of the head & the entire shaft. Any metal to metal rubbing will create static. And a BIG one--I had this problem-- Make sure that NO bare antenna wire touches the FRAME. It's conductive (The frame) and will destroy radio reception.
Lloyd
Old 03-22-2006, 05:03 PM
HookBall
I had the same problem with my Trex. I tried everything, and then I brought a ParkBec 6Volts. Installed it and my glitchie servo problem went away. Heres the link www.dimensionengineering.com/ParkBEC.htm.
Good pricing about $25.00. I also have faster servos once I put in the ParkBec.
