Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Taill drive gear moves up and down?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 04-02-2006, 05:42 PM
Rello
Default Taill drive gear moves up and down?
hi all,
i just realized, that the tail can freely move up and down. it can even move that far, until the little gear touches the main drive gear.
is this normal?
because now the sidewalls can rub against each other.
is it normal?
does someone else have this kind of free movement?
- - - its a XL CPM - - -
Regards,
Marcel
Old 04-02-2006, 10:50 PM
H0ndaJunkie
Default RE: Taill drive gear moves up and down?
Nope, I've got a CDE, an HDE, and I built another HDE for a friend, and none of them have had that much play in them.
Is the gear able to move up and down on the shaft, or does the whole thing move up and down?
Old 04-03-2006, 06:52 AM
Rello
hi,
the whole thing moves!?
time to get a new one?
Old 04-03-2006, 08:56 AM
H0ndaJunkie
Yeah, that's not good.
You might try glueing the shaft inside bearing and the gears, which should stop the whole thing from moving up and down. You'd need to be caredul to only get the glue on the shaft, and not on the bearings etc. If that doesn't work to hold it in place, which it should, you'll need to get a new front tail gear setup.
Old 04-03-2006, 02:33 PM
hdoc
DON'T GLUE anything. If the gear is loose on the shaft-Get a new whole new one. If the bearings are loose in the block, repace them with the bearing loctite they supply in the kit--Only a speck on the outside race.
Lloyd
Old 04-03-2006, 04:55 PM
Rello
not the gear is loose - the whole shaft is moving...
ok, i will get something new.
does it make sense to go with upgrades?
when i have to take everything(!) apart, i thought about the follwoing:
http://cgi.ebay.com/MicroHeli-CNC-Ma...QQcmdZViewItem
http://cgi.ebay.com/ALIGN-T-REX-450-...QQcmdZViewItem
or better this tail gear?
http://cgi.ebay.com/MicroHeli-Front-...QQcmdZViewItem
but i don´t know if the top gear is included?
or only replace the back with a standard one
http://cgi.ebay.com/T-REX-Complete-T...QQcmdZViewItem
thank you all for your thoughts
Old 04-04-2006, 02:37 PM
Rello
opinions on the added value if i go for microheli parts?
need to order to fly as soon as possible again....
Old 04-05-2006, 09:27 AM
rcflyerdave
I had my aluminum tail drive gear at the front start slipping the shaft on the fourth flight.I am going to put the plastic gear/shaft back on.One of the aftermarket gears above looks like it has a set screw.That looks like the way to go.Any comments?
Dave
