Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 T-REX Main Gear Installation... >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-18-2006, 07:33 PM
chazdraves's Avatar
Default T-REX Main Gear Installation...
I'm sure this is a simple question, but I can't seem to get the one-way out of the main gear. I stripped off 20% of the teeth and it's causing a good deal of wobble, so I'd like it out
Any tips? I see the manual suggests LocTite-ing the one-way, so I presume it is LocTite that I'm up against, but 5 minutes of direct heat from the hair dryer didn't seem to loosen it at all.
Many Thanks!
- Chaz
Old 10-18-2006, 07:49 PM
Default RE: T-REX Main Gear Installation...
I haven't had to do one yet but Align does sell a tool to remove the one way bearing so I would assume that's probably the only way to do it.
Mark
Old 10-18-2006, 07:52 PM
chazdraves's Avatar
But here's the deal: I've got 6 new main gear sitting right next to me and I want to fly tonight... See where this is heading
- Chaz
Old 10-18-2006, 07:56 PM
FLYMIKE's Avatar
Even if there isnt locktight they are snug. I use sockets. I put one on the bottom thats big enough to swallow the one way and tap another the same size on top with a hammer. Works for me.
Old 10-18-2006, 09:52 PM
use a plier and break off the plastic until you can remove the one-way, i buy gears with one way bearing for safty so it wont go out while flying using my old one
Old 10-19-2006, 03:32 AM
My Feedback: (14)
Culverson's Avatar
Invest in $5 buck Align tool, until then get a socket that fits over the lip. Then w/smaller socket (not small enough to wedge inside bearing) using a C-Clamp press it out slowly.
You can drive it out with hammer, but you could damage the top edges of the bearing. After done, always flush the bearing with alchohol & use light oil like Marvel or possibly trans-oil. Its very important to service the bearing, or its service will be shortened drastically.
With the Align tool, it takes minute at best.
Old 10-19-2006, 10:11 AM
chazdraves's Avatar
Yes, I can see a One-Way removal tool in my future.
Ironically, the socket thing was exactly what we did. Great minds must think alike?
Thanks, folks!
- Chaz
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
