Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 HS-56HB's in TREX 450SA >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-21-2006, 10:42 PM
Wazmo's Avatar
Default HS-56HB's in TREX 450SA
I purchased Hitec HS-56HB's before the TREX 450SA ARF arrived. The servos have two mounting holes on each tab, but the heli side frames are drilled for single holes, as with HS-55's or S75's. Also, the 56's side-mounting tab gets in the way of mounting the servo with the tab inside the frame as depicted in the instructions. Has anyone mounted 56's in the new 450SA?
Old 10-21-2006, 11:02 PM
Default RE: HS-56HB's in TREX 450SA
Cut off the side mount tab and drill a hole in the servo where you need it.
Don
Old 10-22-2006, 10:53 AM
I would put the HS-65's in it . The direct shot to the swash plate will put a load on the 56's and they only have 17oz's of torque it might strip one. The hs-65's have 31ozs of torque i don't think you will strip one of these in flight. The 65's fit it the frame very good also and the backer plate that align sent will work too. This is just JMO.
Old 10-22-2006, 06:58 PM
Wazmo's Avatar
The instructions recommend S75's which are rated at 17.2 oz/in torque, so I expect the 56's should be sufficient.
Old 10-23-2006, 05:41 AM
Hard landings are the enemy of low torque servos.
Old 10-23-2006, 12:31 PM
yes i had a bit or a hard landing and the servo stripped when i took off i went to the side and i almost crashed until i gave full left so the other servo tries to levl ccpm versio--- so i almost crashed my 30 dollar blades because of weak blades so change to hitech 65
Old 10-31-2006, 09:52 PM
Crash Bandicoot's Avatar
Any others you guys recommend (JR)
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
