Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 What will a T-rex 450 xl lift >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-28-2006, 07:45 PM
Default What will a T-rex 450 xl lift
What will a T-rex 450 xl lift and still be flyable up to 200 feet (no fancy flying)? As far as a camcorder and rig?
Old 10-28-2006, 08:22 PM
Default RE: What will a T-rex 450 xl lift
im pretty sure that a real camcorder would be very difficult to lift but i think it could lift it based on the amount of thrust i was feeling when i was setting up mine. they do make the mini color cameras for that purpose though. but i dont really know the answer to your question.
Old 10-29-2006, 06:15 AM
Depending on power output of your bird, would look at small lightweight 5megapixel cameras. For a handycam, you will be looking at 50 sized like the trex 600
Theres a special camera mount that someone sells on the net for still cameras thats an extension to the trex 450's landing skid.
Old 10-30-2006, 01:07 AM
So a T-rex 600 could lift 2 lbs? And be more stable than a 450 xl?
Old 10-31-2006, 01:46 AM
ive been thinkning about attaching a camera to my trex too, these cameras are the best i've found to use
http://www.x10.com/cameras/cameras_wireless.html
Old 10-31-2006, 08:20 AM
The problem with those Xcams is they use a directional antenna. Great for fixed setups where you can get extra range pointing the antenna at the RX, but not good for heli use where the antenna will be moving...
The (cheapish) 2.4GHz minicams (spycams) with the tiny wire antenna are ideal for a TRex. Even with the weight of a 9v battery the performance hit is close to zero.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
