T-Rex heli For all you T-Rex lovers out there, this where you can post!
twitchey!
Old 10-31-2006, 12:01 PM
My Feedback: (17)
Default twitchey!
My t-rex xl is twitcher, very sensitive, should i bring the ball links in 1 hole on the servo horns?
Old 10-31-2006, 12:07 PM
Default RE: twitchey!
Do you have weights on the flybar? They should have been supplied in the kit. They slow down the responce without limiting control travel which is what you'll get if you move servo holes.
If the weights are not enough, use expo on the cyclic control. This will slow down the response near stick centre without limiting overall travel.
As a last resort, change servo hole on every servo conected to the head by an equal amount, one hole should do it.
Old 10-31-2006, 03:02 PM
My Feedback: (17)
nope, no fly-bar weights came with it. and i can try the expo.
Old 11-01-2006, 03:45 PM
My Feedback: (17)
adjusted servoes and added some expo...LOVE it!
Old 11-01-2006, 07:21 PM
If you add expo like +120 does that lessen the sensitivity around center or do I subtract expo.I read it in the instructions before but Im kinda slow around the center myself .
Old 11-01-2006, 07:49 PM
My Feedback: (17)
Well, for my radio, it was more sensitive with out any expo, i added about 30% and thats the slow i was looking for at center. I am flying with an Airtronics Stylus here, so, I am un-sure about the use of your radio. Good luck!
Old 11-01-2006, 07:54 PM
Thanks, I have a 7chp ,Guess ill try some experimenting tommorow.
Old 11-02-2006, 11:22 AM
WhtBronco's Avatar
With Futaba you use negative expo to reduce sensativity around center.
With JR you use positive expo to reduce sensativity around center.
I believe only SE kit comes with the flybar weights. The 450 XL HDE kits I've seen certainly don't include the weights.
Old 11-02-2006, 12:08 PM
I recived a T-REX XL with flybar weights...2 sets for some reason...
Old 11-02-2006, 12:19 PM
ORIGINAL: WhtBronco
My 450XL HDE came with weights. I added my df4's weight and a small pinion gear as extras to slow the response. It's just too sensitive for a beginner.
Old 11-02-2006, 12:28 PM
ORIGINAL: NIGHTWING1
You prolly got Flytoolows weights. [:-]
Old 11-03-2006, 07:51 AM
My Feedback: (17)
I'm flying the SE and CDE XL. The SE is the only 1 with the flybar weights. How far out should the weights be?
Old 11-05-2006, 07:48 AM
The further out they are, the slower it will respond. Start with them fully out and make sure the flybar is properly balanced. If it's too docile you can slide them towards the head, but always ensure the bar is balanced and that the weights are firmly fixed. The only thing holding them in place is the small grub screw. If one comes loose in flight it will be thrown down the bar and unbalance the whole head.
Old 11-05-2006, 07:52 AM
exeter_acres's Avatar
ORIGINAL: rcboosted
it is not designed as a beginner Heli
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
