Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 tail bobs up and down?? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 11-02-2006, 09:51 AM
Default tail bobs up and down??
hi
can any of you guys please tell why the tail of my SE bobs up and down slightly??tail blades not balanced maybe??
Old 11-02-2006, 11:03 AM
emosolo's Avatar
Default RE: tail bobs up and down??
Morning,
I have read articles before that indicate a up and down vibration as being caused by unbalanced rotor blades...
Regards,
Solo.
Old 11-02-2006, 11:26 AM
WhtBronco's Avatar
Mine did this for 1 flight. I landed after just a couple minutes of it and closely inspected the heli. I found the tail belt shredding. After replacing the belt and adding the MX400 idler pulley the tail is smooth again.
It's easy to see if the belt is shredding since there is black dust all over the tail housing and main gear.
Old 11-04-2006, 09:26 PM
A friend of mine has a SE that does that.By increasing it got rid of the problem on his heli.
Old 11-05-2006, 12:01 AM
ORIGINAL: jgeorgic
I'm unsure of what is being increased( you didn't specify), but........
Low headspeed
Blades out of balance or track
Heli not balanced on center of gravity
Drag in the system
Screws too tight in the mixer arms
or........
Using the blue main gears withouth the tail reduction gears.
Hope this helps,
Don
Old 03-31-2007, 06:27 AM
hey dude try higher head speed / less pitch
Old 03-31-2007, 09:32 AM
johnnychimpo's Avatar
Low head speed or your blades need to be balanced and tracked. What motor, pinion, and battery are you using?
Old 03-31-2007, 01:57 PM
Missileman's Avatar
This thread is from November
Old 03-31-2007, 05:57 PM
LOL, i didnt even check. Good job diggin up an old post jizthegoods for your first post on RCU![sm=lol.gif]
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
