Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Lipo Detector-ESC -Pinion Question............. >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 11-04-2006, 09:37 PM
Default Lipo Detector-ESC -Pinion Question.............
Here is my setup:
T-REX XL
Align BLG35X ESC
Align 3550V Motor
Thunder Power 2100mAh 3 cell Pro-lite battery
Thunder Power Extreme 2070 mAh 3 cell battery
Question 1:What is a good setting for the lipo low voltage detector.I currenty have it set to go off at 9.9V
Question2: On the ALign ESC is the setting for timing correct when set to #2 Mid ?
Question 3: I have it set up with a 11 tooth pinion...Any thought on using that pinion.
Thanks for your help !
Old 11-05-2006, 07:40 PM
FLYMIKE's Avatar
Default RE: Lipo Detector-ESC -Pinion Question.............
question 1, yes
question 2, yes
question 3 if you are using white gears then the 11t pinion should work fine. but if you have the blue gears all around then switch to 13t pinion so tail doesnt drift.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
