T-Rex heli For all you T-Rex lovers out there, this where you can post!
Metal blade grip
Old 11-05-2006, 11:24 PM
Default Metal blade grip
Since I keep breaking the plastic blade grip, I was wondering if it's wise for me to upgrade it to metal. I remember SE was not recommended for beginners due to constant crashes that will cause metal fatique which cannot be detected until it flys itself apart in the air. So if I crash often, should I upgrade to metal blade grips? Or I'm better having parts break so I can replace it rather than not knowing and lose the heli in the air. I'm also worried that since the metal blades grips are stronger, the shock will just transfer to the rotor head. And if I upgrade that, it'll just keep going down the head assembly until the weakest link. What are your thoughts?
Old 11-05-2006, 11:32 PM
FLYMIKE's Avatar
Default RE: Metal blade grip
checkout hobbyjapan2000 under upgrades for trex. they have complete blue cnc full head and tail for 99.90usd
Old 11-06-2006, 02:39 AM
Thanks for the link. If only they're available in grey. Are these any good? They seem like oem knock-offs, which could be using bad alloys that wouldn't hold up.
My original question remains. Should I upgrade to metal or not?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
