Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Trex Spinning out of control >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 11-06-2006, 01:21 AM
Default Trex Spinning out of control
I had a major high speed crash with my Trex SE. Had to replace , main & tail rotor blades, landing skid, main shaft, T arm for tail pitch control where ball link & control rod join. When I get just about enough RPM to lift off. It goes crazy in a fast anticlockwise uncontrolable fast tail spin. I have broken the centre tail control rod holder just under the horizontal stab, so as a short term solution I've used some wire about the tail boom to help hold it up. I have to mail order the tail control rod holder (below horizontal stab) but want to know if its possible that something else is wrong with it, so I can order everything at once.
What are other areas I should be looking at relating to this problem?
Would it be possible to be a gyro problem? How ncan you test if a gyro is ok or not?
Belt problem, not enough rpm at the tail?
Thanks for the help.
Old 11-06-2006, 04:23 AM
Default RE: Trex Spinning out of control
Figured it out. Had to flick the reverse switch on the gyro. I had installed a new servo so guess I've connected it reversed.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
