Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 SE Pitch and throtle curves >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 11-08-2006, 07:54 PM
Default SE Pitch and throtle curves
I Have a xl with white geatrs and its rock steady .I just got finishd building a Se with the blue gears ,and the tail drifts a little counter clockwise and the gyro dosent hold as well when I turn up the gain a little it wags ,I am pretty sure this has to do with pitch curve vs throtle curve,
I what is everyone using on there se with the blue gear for there curves and how well its working for ya.
I have the 401 with 9650 on the tail.
also what pinion are you using?
thanks
Old 11-09-2006, 06:09 PM
Default RE: SE Pitch and throtle curves
Never mind I just swiched to the white tail gear and it works great now,Thats a pain to change out you have to almost split the entire frame [:@].
Old 11-09-2006, 07:46 PM
FLYMIKE's Avatar
with the blue gears you have to increase head speed or tail will drift. I use 13t pinion. Mike
Old 11-10-2006, 06:30 AM
I had the same thing with mine... I just changed the pitch curve so that the head speed would come up, now the tail won't drift at all.
Old 11-10-2006, 02:50 PM
What are the pitch and trottle curves you are using?
Old 11-10-2006, 03:36 PM
This is just something I worked up to make the head speed come up, but the pitch curve I built is:
1 - 0%
2 - 9.5%
3 - 18%
4 - 27%
5 - 38%
6 - 64%
7 - 100%
I have not tried this in forward flight so I don't know how well it will / would do, so be careful! The throttle curve is a slight bell curve 1 @ 0%, 3@50% & 7@100%
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
