Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 radio, cristal, or interferance? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 11-09-2006, 03:50 AM
FLYMIKE's Avatar
Default radio, cristal, or interferance?
radio dont work and when I get it close to heli all servos srarts glitching. take it away and glitches stop. Is the cristal bad? or esc?
Old 11-09-2006, 02:39 PM
BarracudaHockey's Avatar
Default RE: radio, cristal, or interferance?
Well its probably the......................
Wait..........we probably need more info.
How about what radio and reciever are you using?
Do you have pcm/ppm set correctly for the receiver in use? Is it on the correct channel? Are you trying to use a JR reciever with a Futaba transmitter?
More input man!
Old 11-09-2006, 02:55 PM
FLYMIKE's Avatar
I put together an cde and when setting up servos for ccpm with motor disconected control servo funtions were reversed only on elevator and could not reverse it. Then sudenly no servo funtion at all exept when I put tx close to heli then all servos glitch.
I plugged motor back and esc dont go through the series of beeps anymore but if i put tx close its starts to glitch and motor spools up.
using airtronics rd6000 super ppm and is set to ppm and align35 esc. Im thinking its the esc. Mike
Old 11-09-2006, 03:00 PM
FLYMIKE's Avatar
Oh, swashplate came apart too.
Old 11-09-2006, 04:53 PM
FLYMIKE's Avatar
I tried another esc and the same thing happened. so maybe its the rx. or both esc are bad.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
