T-Rex heli For all you T-Rex lovers out there, this where you can post!
trex 450 se
Old 12-25-2006, 11:28 PM
mirage-twin
Default trex 450 se
I just got the trex 450 se with motor/esc and I would like to see where and how people are mounting there batteries and radio gear, thanks.
Also, what battery is recommended for this heli?
Old 12-26-2006, 06:18 PM
johnnychimpo
johnnychimpo's Avatar
Default RE: trex 450 se
I would say any 1700 to 2100mah battery with at least 15c discharge 3cell 11.1 lipo.
I would put the battery where the manual says until you get the heli balanced. it all depends on the weight of the battery and where you put the rest of the radio gear.
Old 12-27-2006, 04:49 AM
jobybett
Hi,
I've just bought a 450se too, i've been scanning the forums and web for a while and this is the list that I have settled on its towards the top end of spec so its a bit pricy comming in at about $1200
Tail Servo FUTM0654 S3154 Digital High Torque Micro Servo
Main Servos HS-65MG
Gyro GY401
TX JR 9303 Heli
RX JR R790
Charger Thunder Power 1010C Lithium Battery Charger
Balancer Thunder Power 205V Lithium Battery Balancer
Battery Thunder Power Pro Lite 2100mAh 11.1V 3 Cell
