Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Tail wag gone!, but at what price?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 12-28-2006, 08:10 AM
sunkan
Default RE: Tail wag gone!, but at what price?
I don't really have anything to contribute but I also use an HS-50 and GY240.
I have 7mm between center of servo arm and center of the ball.
I have 100% gain on my GY240, it's not enough for me because my head speed is too low for the reduction gear I am using. But this will be fixed with a bigger pinion for my motor (I have change motor recently, with 430L 13T it worked good).
What I would try would be to plug in the HS-50 in the rudder channel directly and move it really slowly to see that it is not twitching or anything. Then I would also put some load on it (put a finger on it so that the servo needs to work a little) and see that it is still smooth.
Hope you find the cure.
Old 12-28-2006, 12:47 PM
johnnychimpo
johnnychimpo's Avatar
Sorry about not reading the post all the way. It was a long read and needed some breaks or paragraphs. The TE/ LE issue seemed to work for me with my smaller heli's like the HDX300 and Walkera 22A but i was not sure about the T-rex.
