T-Rex heli For all you T-Rex lovers out there, this where you can post!
tail
Old 01-01-2007, 08:04 PM
Default tail
hi all i got two trex one the tail goes clockwise the other goes the counter clock can some one help thank you kevin
Old 01-01-2007, 08:29 PM
Default RE: tail
It depends on how you twist the belt in the tail boom.
The instructions show you how it's done properly.
Old 01-01-2007, 09:40 PM
Default RE: tail
which way should it spin
Old 01-01-2007, 11:20 PM
Default RE: tail
When looking at the right side of the heli, the tail should be spinning counter clockwise.
Since helicopters are very sensitive machines, I would like someone who truly knows what they are talking about to also reply as I am just going by the instructions book, I would hate to lead you in the wrong direction.
Old 01-02-2007, 10:31 AM
Default RE: tail
I've watched the Famous Finless videos, he talks about the tail moving up toward the main blade. Which means they should turn counter clockwise when viewing from the right. So yes you are correct.
Old 01-02-2007, 11:28 AM
Default RE: tail
That's exactly correct. For all RC helis that I've ever seen:
- Main rotor turns clockwise (when viewed from above)
- Tail rotor turns counter-clockwise (when viewed from the right side of the heli)
Old 01-02-2007, 03:07 PM
BarracudaHockey's Avatar
Default RE: tail
Take a look at some of the older machines like the Kavans...
Anyways, the leading blade should go up and into the main rotor wash so the correct answer is ..................counter clockwise. The way to remember is no matter the tail design, if the tail rotor hits the ground it should kick dirt towards the front of the heli.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
