Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Align BL35G ESC Question >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-02-2007, 12:31 PM
haz
My Feedback: (17)
Default Align BL35G ESC Question
Iam changing out my power setup on my t-rex. I had a Align 25amp esc and 420lf motor 3 hs55 servos and 1 hs56 on the tail with a 401 gyro this setup worked well on 3s 2100 packs.Now i have on order the align BL35G esc and the 430L motor and i upgraded the tail servo to a Futaba S3154 Digital Micro servo.Will this setup work without any power/bec issues? The instructions for the esc say 3 cells Lithium 3 servos,the 25 amp esc said the same thing but it ran fine with 4 servos and a gyro.
Old 01-02-2007, 01:06 PM
Default RE: Align BL35G ESC Question
That set up will work just fine without any power issues. If you have the 3550kv 430 L you want to run a 13T pinion - if you have the 4050kv version - you want to probably run an 11T pinion.
Old 01-02-2007, 01:36 PM
haz
My Feedback: (17)
Thanks bbking9 its the Align 430L 3550 KV Motor .
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
