Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 How I installed My Electronics >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-03-2007, 09:09 PM
Heli_Harry's Avatar
Default How I installed My Electronics
This is how I setup the Electronics in My T-Rex.
This is just for an example of how I did it.
Have fun
PS: The grey circle under the battery tray is my Li-Po Alarm
ID:	590091   Click image for larger version
ID:	590092   Click image for larger version
ID:	590093   Click image for larger version
ID:	590094   Click image for larger version
ID:	590095   Click image for larger version
ID:	590096   Click image for larger version
ID:	590097   Click image for larger version
ID:	590099   Click image for larger version
ID:	590100   Click image for larger version
Old 01-03-2007, 10:09 PM
Default RE: How I installed My Electronics
Nicely done! One way I tell if someone is good at something is that they make it look easy. Doc
Old 01-03-2007, 10:35 PM
very clean looking
Old 01-03-2007, 11:17 PM
Dynamic's Avatar
Is there a reason that you ran your servo wires on the outside instead of the inside. IMHO that creates a cleaner look and the zipties keep it out of mechanics. Other then that your bird is looking pretty prime. Nice gyro mounting I'm curious to see how well that works out for you. I'd also say that servo wires could be shortened, but the extra clean cable management allows me to let that slide.
Old 01-04-2007, 12:09 AM
Heli_Harry's Avatar
Thanks all, It flies great.
Actually this was my throw back together wiring job after my last crash (dumb thumbs).
I'm waiting on a new tail pitch lever, as I snapped mine off, actually I think it got damaged in the crash.
I landed and when I wrent to take off again it just piroed so I was lucky it did not snap in the air and cause a new crash.
No need to shorten the wires as a ziptie does the trick just fine and
when I switch over to digitals the old ones will be ready for the next project.
As for the outside, I'm not going to worrie about seeing 2 inches of wireing (AKA I was lazy)
Mabie when I put the digitals in I'll throw some sleaving over it.
Old 01-04-2007, 08:00 AM
armycopter's Avatar
Looks super! What kind of servos are you running right now?
Old 01-04-2007, 12:50 PM
Heli_Harry's Avatar
Hitec 65MG on the head
JR DS3400G on the tail
Old 01-06-2007, 12:06 AM
thank you!
i was just trying to figure out where to put all that gyro wire! now i know what to do with it.
Old 01-10-2007, 10:50 AM
My Feedback: (17)
jblloyd's Avatar
Just curious ... Futaba recomends that the gyro be mounted at least 10cm from the motor to reduce interference. Looks like your gyro is pretty close to your motor. Have you flown this configuration?
Old 01-10-2007, 12:05 PM
Heli_Harry's Avatar
Yes I have flown it quite a bit
Not sure on the Futaba stuff
From everything I have read the JR is a bettter Gyro
Old 01-10-2007, 12:14 PM
My Feedback: (17)
jblloyd's Avatar
Thanks, I may move mine to the bottom of the frame. I have already had one broken by the flybar in a crash.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
