Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 My DX6 Settings for the T-Rex 450 SE >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-05-2007, 01:20 PM
Heli_Harry's Avatar
Default My DX6 Settings for the T-Rex 450 SE
I thought I'd pass this along to help others get this set up.
. Model . Align T-Rex 450XL SE CDE
. Parameter . Function . Value . Notes
. Model . Type . TYP . HE
. Data Reset
. Dual Rate Switch . SW . CF . Combined Flight Mode Switch
. Gear/ Gyro Gain SW . Ger . A . Aileron Switch
. Model Selection . MDL . 1
. Model Name . 1 . REX
. Servo Reversing . THR . Norm
. . AIL . Norm
. . ELE . Norm
. . RUD . Rev
. . Ger . Norm
. . PIT . Rev
. Dual Rate 0 . AI0 . 100%
. . EL0 . 100%
. Dual Rate 1 . AI1 . 100%
. . EL1 . 100%
. Exponential 0 . AI0 . 0%
. . EL0 . 0%
. Exponential 1 . AI1 . 0%
. . EL1 . 0%
. Sub-Trim . THR . 0
. . AIL . 0
. . ELE . +35
. . RUD . -1
. Gyro SW Center Point . Ger . 0 . Value x .6 = Center Point (42 = 25%. 83 = 50%. 125 = 75%)
. . PIT . -20
. Travel Adjustment . THR . -100%
. . THR . +100%
. . AIL . -108%
. . AIL . +103%
. . ELE . -104%
. . ELE . +102%
. . RUD . -150%
. . RUD . +150%
. Gyro Position 1 . Ger . -45% . Value + Sub Trim % = Gyro Gain (Do Not Exceed -150)
. Gyro Position 0 . Ger . +35% . Value + Sub Trim % = Gyro Gain (Do Not Exceed 150)
. . PIT . -100%
. . PIT . +100%
. Throttle Hold . HLD . 0%
. Pitch Curve Normal . PLN . 40% . -2 Degrees
. . P2N . 50% . 0 Degrees
. . PHN . 100% . +10 Degrees
. Pitch Curve Stunt . PLS . 0% . -10 Degrees
. . P2S . 50% . 0 Degrees
. . PHS . 100% . +10 Degrees
. Pitch Curve Hold . PLH . 0% . -10 Degrees
. . P2H . 50% . 0 Degrees
. . PHH . 100% . +10 Degrees
. Throttle Curve Normal. TLN . 0%
. . T2N . 85%
. . THN . 100%
. Throttle Curve Stunt . TLS . 100%
. . T2S . 85%
. Revolution Mixing . RVU . -0% . Do not use with HH Gyro
. . RVD . +0% . Do not use with HH Gyro
. Programmable Mixing . Master CH . 4 . Rudder Ch
. . Slave Ch . 4 . Rudder Ch
. Mix Switch Selection . Mix ASW . On . Always on
. Mixing Value . Mix AXX . -45% . Rudder Stick to the Left
. . Mix AXX . -45% .Rudder Stick to the Right
. . Mix Offset . 0 .No Offset.
. CCPM Mixing . CCP . On
. . CP2 . +45% .Travel Adjustment for Aileron Function ( 6 Degrees)
. . CP3 . -52% .Travel Adjustment for Elevator Function ( 6 Degrees)
. . CP6 . -50% .Travel Adjustment for Pitch Function ( +/-10 Degrees)
. Trims . THR . 0%
. . AIL . 0%
. . ELE . 0%
. . RUD . 0% .Must rebind receiver if rudder trim is changed
Old 01-05-2007, 09:25 PM
Default RE: My DX6 Settings for the T-Rex 450 SE
great info harry.....would it be the same for a dx7 ans 450sa. about 3 weeks away from getting it al together,and need the help...thanks...john
Old 01-08-2007, 11:16 PM
robmoney's Avatar
Thank you Harry!
Rob
Old 01-09-2007, 03:41 AM
ORIGINAL: johnnycat500
Not quite, I'll post mine soon, I don't have the radio handy.
Old 01-09-2007, 02:14 PM
good info, no not the same but it'll be close. theres 5 point pitch curves and 5 point throttle curves and they are read in additional ways and viewed. i think the dx7 is easier to use.
Old 01-09-2007, 05:47 PM
Another great setup guide for the DX6 and the SE or SA - http://www.digimemphoto.com/guides/backguide.htm
Also, the manual for the SA has a really good DX6 setup section if you want to download it here - http://www.horizonhobby.com/ProdInfo...ARF_Manual.pdf
Old 01-10-2007, 05:11 PM
Heli_Harry's Avatar
Yes the SA manual is very good reading!
Old 01-11-2007, 04:09 AM
Ok, DX7 setup. This is CCPM, HDE would be the same except normal swash mode and the end-point setups. I have a GY-401 and Hyperion ESC, but I'll give curves for Align ESCs as well, governor in both cases.
This gives gyro mode on the rudder dual rate switch, throttle hold on AUX2 and ties dual rates to the flight mode switch.
[D/R & EXP]:
Position 0
Channel, exp, rate
elev +35% 65%
aile +35% 55%
rudd +30% 100%
Position 1
elev +55% 100%
aile +55% 100%
rudd lin 100%
[Auto D/R EXP]
This is somewhat my preference only, this gives high rates in idle-up 2.
NORM P-0
ST-1 P-0
ST-2 P-1
HOLD P-0
[Reversing sw]
Channels 1 and 5 on normal for throttle and gyro gain, others depend on servos.
[Sub trim]
Set on zero, get everything as close as you can and then trim these. See any 401 setup guide for what to do with the rudder subtrim.
[Travel adjust]
I have all my cyclic servos on 150%, they're JR micros and this gives precisely the right travel to match the swash using the longest horns that came with them. Everything else on 100%
[Swash mix]
3-servos 120 degrees exponential active, all channels on +60
You may have to set some to -60 to get the swash movement correct, depending on your servos and linkages.
[Throttle hold]
-5%, AUX2 switch
[Throttle curve] (Hyperion ESC, governor on. Soft start is too quick so Normal is used for spoolup)
Normal: 3-points, 0% 50% 100%, exp inh
ST-1: 3-points, 80%x3, exp inh
ST-2: same as ST-1
I have also been experimenting with:
ST-2: 5-points, 100% 85% 80% 85% 100%, exp act.
This hints the governor to put in more power at full collective and appears to reduce bogging. Headspeed regulation is still good.
[Throttle curve] (Align ESC, assuming soft start is ON!!! Spoolup with hold switch)
All curves: 3-points, 87%, exp inh
[Pitch curve]
All curves: 3-points, 0% 50% 100%, exp inh
[Revo mix]
all 0%
[Gyro sens]
Rudd d/r switch
Position 0 18%
Position 1 78%
This corresponds to 56% gain in HH mode. Obviously this will vary.
I'm not using any programmable mixes.
Old 01-11-2007, 12:20 PM
Heli_Harry's Avatar
You should put the DX7 in it's own thread so people can find it easier
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
