Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 450 se v2 esc battery and reciver placement >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-15-2007, 10:16 PM
Default 450 se v2 esc battery and reciver placement
were is every one placing the esc battery and reciver. i just finished the assembely and and trying to decide on placement. what tooth pinion are yall running with the 3700 kv motor and wood blades i put the 12 in like the book said to but was wondering if the 13 would be ok without going to carbon blades.
thanks
kenneth
Old 06-15-2007, 10:20 PM
Cleared2Engage's Avatar
Default RE: 450 se v2 esc battery and reciver placement
I have my ESC mounted under the cooling fan and my Rx right next to it (using a 2.4ghz). I'm using the dreaded 25 amp Align esc and it stays cool and doesn't give me any issues. I used to have my receiver mounted on the outside of the frame but there was nothing to protect it in a crash.
Old 06-15-2007, 10:22 PM
I've used the 13 tooth pinion with the wooden blades with the 430 motor and it works fine. I normally use the 325 carbons cause they feel more stable to me.
Old 06-15-2007, 10:31 PM
im using the esc that comes in the kit the rce-bl35x align and a futaba pcm 1024 8ch micro reciever and a futaba 8uap pcm 1024 computer transmitter
thanks
kenneth
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
