T-Rex heli For all you T-Rex lovers out there, this where you can post!
lipo size
Old 06-16-2007, 04:06 PM
Default lipo size
can i use a 20c 11.1 2500 lipo with the trex ? i really haven`t found the min /max mah . anyoe help me out?
Old 06-16-2007, 04:37 PM
johnnychimpo's Avatar
Default RE: lipo size
You can use a 2500mah with a trex no problem. I use 2200, 2170, and 2100 size packs.
Old 06-16-2007, 04:38 PM
Cleared2Engage's Avatar
I'm pretty sure as long as it will fit on the helicopter and it can take off safely you can use just about any mah battery. In the 450XL HDE instructions they say you can go with as little as a 1300.
Old 06-16-2007, 04:39 PM
Bad_Daddy's Avatar
As long as the voltage is correct, the mAh rating of a battery is similar to a measurement of volume. In other words, think of the amp-hour rating like you would the size of a fuel tank on a car. The bigger the fuel tank, the longer it will run.
Old 06-16-2007, 05:57 PM
Don't try a 1250mAH 3e 10C lipo in your Trex 450SE V2. Smoked it in on flight. I hit the lipo alarm in under 2 minute2 and pulled it off and just set it quickly down on the concrete and got away from it for awhile. It's puffed pretty good and a wire came off of it!
Flew great in my Walkera 36 too. I should have used common sense.
HS
Old 06-16-2007, 06:51 PM
Yeah, as long as it can deliver the required current (amps) for your particular setup, and does not weigh too much, you're good to go...
Old 06-17-2007, 03:09 AM
has anyone tried the 5000 max amps packs? or the 10,000
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
