T-Rex heli For all you T-Rex lovers out there, this where you can post!
TIGHT BLADE
Old 09-08-2007, 10:08 AM
Bretuk
Bretuk's Avatar
Default TIGHT BLADE
One of my carbon fibre blades on my Trex450seV2 is very tight in the grip which wen the heli is spooled up wobbles cos it cant straighten up. It must be thicker than the other blade which is ok in the grips. Can it be sandpapered down a little to fit
Old 09-08-2007, 11:09 AM
madmodelman
madmodelman's Avatar
Default RE: TIGHT BLADE
As a matter of interest both mine are fairly tight but I just make sure they are in line before flying and have no probs. I'm no expert on heli's but do NOT take material out of the grips for definate. What happens when you swap blades in the grips?, that will tell you where the problem lies.
Old 09-08-2007, 11:20 AM
exeter_acres
exeter_acres's Avatar
as I posted on your other post...it is common to have to sand the blades just a bit because they are tight in the Aluminum grips....
sand till they fit, rebalance and go fly
Old 09-08-2007, 12:21 PM
Bretuk
Bretuk's Avatar
the one blade is tight in the other grip too, its the blade
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
