Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Need help with T-Rex 450 SE setup ..have AR6000 Rx and DX6 Tx
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 09-30-2007, 12:55 AM
schne564
Default Need help with T-Rex 450 SE setup ..have AR6000 Rx and DX6 Tx
I just got my T-rex 450 SE in the mail and I can't get it to work with my Tx and Rx. For simplicity I just plugged the Castle Creations 35A ESC into the AR6000 Rx (THR chnl 2). I turn on my DX6 Tx and plug the TP 2100mah 3s lipo in. The ESC makes a beeping noise and then the red led continues to blink. I throttle up and nothing. Any suggestions?
When I plug my servos in they seem to work. Also, there are 3 servos to plug in not including the tail servo. I only have a spot for AIL and ELE. Where does the other servo plug in?
I also have a GY240. The tail servo does plug into the gyro right? Where does the gyro plug into the AR6000
Any help would be greatly appreciated. Thanks!
Old 09-30-2007, 08:47 AM
stevennh
Default RE: Need help with T-Rex 450 SE setup ..have AR6000 Rx and DX6 Tx
[link=http://www.digimemphoto.com/guides/backguide.htm]DX6 Setup with 450SA/SE[/link]
This link worked great for me. I used it to install my DX6 on my SA.
Steve
Old 10-01-2007, 12:43 PM
rlsloan
1. Throttle is channel 3.
2. The 450 has (3) servos driving the swash in 120 degree configuration. Collective ch 6, yaw ch 2, roll ch1. Tail is ch 4. Gyro gain ch 5.
