Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 How to install tail servo 9650? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-22-2007, 12:52 PM
Default How to install tail servo 9650?
I'm trying to install the tail servo (Futaba 9650) to the 2 metal pieces (the servo mounting metal pieces) onto the tail boom of my Trex 450 SE V2. The 9650 has two ears, each of which have two large holes, that don't fit any of the screw from the kit. The instruction manual doesn't explain well the process of installatio of the tail servo either. Could somebody specifically tell me how this can be done? Thank you in advance. I am a beginner and this is my firt heli. [:-][:-]
Old 10-22-2007, 02:50 PM
Default RE: How to install tail servo 9650?
You need to use the rubber dampers and brass grommets that came with the servo. That will considerably narrow the whole so that the screw can grip something.
Old 10-22-2007, 07:18 PM
p01rogue's Avatar
Or Just use washers .
took a pic for ya.
Old 10-22-2007, 09:38 PM
I don't think the 4 bolts that came with the metal mounts are long enough to secure the servo in the way that you guys are showing me. Probably I need to go get longer bolts... Thank you folks. [&o][&o]
Old 10-22-2007, 09:49 PM
p01rogue's Avatar
ORIGINAL: helibutt
I did'nt have to get longer hex head srews.(bolts)
Old 10-23-2007, 11:06 AM
I think something parts are lacking in my kit. I have neither 4 washers or long enough bolts. I'm stuck here. This sucks. I have to get more hardware, but now I know how I can install the tail servo. Thank you guys. [][]
Old 10-23-2007, 11:21 AM
Get many bolts (different lenghts) and nuts, you will need them after crashes or just to have as spares, it sucks to have your heli without flying because you are missing 1 screw!!!!! and believe me, that happens, better to have many to choose from.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
