Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 and 600 T-REX PRO >
and 600 T-REX PRO
T-Rex heli For all you T-Rex lovers out there, this where you can post!
and 600 T-REX PRO
Old 10-25-2007, 05:54 AM
Default and 600 T-REX PRO
I am building a 600 pro and have 2 questions, first the manual does not show the rod length of the rod for the elev. nor does the kit have one,and the muffler hits the frame so it won't bolt up without some sort of spacer.........this is my first heli build the others I have were bought already built.
Old 10-25-2007, 01:39 PM
Default RE: and 600 T-REX PRO
I have my 600 nitro,I build it everything come in the kit,I use align mufler with no problem,look in the kit may have the rod in there,diff with 450.manual for 600 you have to look right on the picture to see the link.I hope this may be help.
Old 10-25-2007, 08:24 PM
There 2 rods for the elevator servo. Its on page 16 on the pro maual. 50mm to the center of the ball link. My muscle pipe 5 hit the bottom part (frame brace) I just filed it down why lots are going with the align pipe
Old 10-25-2007, 08:40 PM
BarracudaHockey's Avatar
Also if you dont file the frame and eliminate the rubbing it will wear a hole in your muffler.
Old 10-26-2007, 05:37 AM
I found an extension so the pipe clears it now,and I found the rod...........thanks
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
