T-Rex heli For all you T-Rex lovers out there, this where you can post!
6ex or dx7?
Old 11-27-2007, 11:02 PM
oly_rcer
Default 6ex or dx7?
just wondering if givin the choice would you prefer a futaba 6ex fasst or a spektrum dx7?i race cars and trucks and love the 2.4 systems but to be honest the spektrum radios(at least the surface radios)really suck.hoping if i get a dx 6 or 7 the quality will be better than the pistol grip radios or would the futaba be a better radio?thx
Old 11-27-2007, 11:14 PM
soop7667
soop7667's Avatar
Default RE: 6ex or dx7?
All I know for sure is that someone's posted a warning notice that there's been numerous problems reported with the Fasst system. Personally, I've not experienced a single problem with my DX7. I've looked at the DX3, pistol grip radio for cars, and it didn't look like anything special to me, but I don't really know car radios at all. As far as my DX7 goes, I think it's a great radio.
Old 11-28-2007, 04:42 AM
madmodelman
madmodelman's Avatar
What problems have you heard about with Futaba FASST systems?
I have had no problems nor have heard of anyone else have them.
Old 11-28-2007, 08:07 AM
TheBum
The 6EX does not have subtrims nor does it have a separate throttle hold pitch curve (it uses the Normal mode pitch curve). Both are quite important to have in a heli, IMO.
Old 11-28-2007, 08:30 AM
hennesseylord
dx7 all the way!
Old 11-28-2007, 09:14 AM
madmodelman
I'd better throw mine in the bin then.
Old 11-28-2007, 09:49 AM
soneebee
soneebee's Avatar
I would go for the DX7.. it has more features that you will need... the 6EX FASST is an entry level radio...
Old 11-28-2007, 10:30 AM
BarracudaHockey
BarracudaHockey's Avatar
Lack of sub trims on a 6ex make it a nusance to setup a heli. If I had to choose between that and a DX7 I'd get a dx7 any day, and I've been flying Futaba for a LONG time.
Old 11-28-2007, 10:57 AM
BryFlyGuy67
BryFlyGuy67's Avatar
A lot of my buds have Futabas, but I love my DX7.
Old 11-28-2007, 04:00 PM
ekotil
If you go Spektrum it has to be a 7 but if you do heli's mostly get the heli version because of throttle movement and switch layout. I have one of each but prefer the heli version if I only could have 1!
Old 11-28-2007, 04:08 PM
hennesseylord
the dx7 is exactly the same heli or airplane version...only difference is the throttle has a ratchet feeling on the airplane while the heli version is smooth. switch layout is the same correct?
Old 11-28-2007, 09:40 PM
tippy
ORIGINAL: TheBum
I believe the 6EX 2.4GHZ version DOES have a TRIM menu but the regular 6EX* does not.
Old 11-29-2007, 09:14 AM
George1234
ORIGINAL: tippy
ORIGINAL: TheBum
You're right, it does have a trim menu, but does not have a "sub-trim" menu.
George
Old 11-29-2007, 07:26 PM
JayDizzl879
ORIGINAL: hennesseylord
Some switch positions are a little different on the aero version.
Old 11-29-2007, 08:26 PM
tippy
ORIGINAL: George1234
ORIGINAL: tippy
ORIGINAL: TheBum
George
From the DX7 manual (referring to SUB-TRIM):
The Sub-Trim function allows you to electronically adjust the centering of each servo. Sub trim is individually
adjustable for all seven channels, with a range of + or - 125% (+ or - 30 degrees servo travel).
From the 6EX_2.4 manual (referring to TRIM):
Adjusting the trims with the trim levers changes the servo’s position in increments of “4.” If finer adjustments are required, land the
model, then enter the program as described below to adjust the trims in increments of “1.”
So ... you are right ... the 6EX_2.4 does not have a menu called "sub-trim" but it's "TRIM" menu seems to perform a similar function to the more commonly known "sub-trim" menu ...
Some say ATV ... some say EPA ... both do the same thing.
Old 11-29-2007, 09:54 PM
George1234
But with sub-trim, you can you can put in an offset to center a servo, and your trim menu will still be centered. If you center a servo using trim, your flight trim will also be off, and if you change trims for flight, centering will be off again!
George
Old 11-29-2007, 11:16 PM
soop7667
soop7667's Avatar
I could take a pic of it. It's a print out that's been posted at the air park I fly at. It says something about interference from other FASST radios if memory serves. I didn't read the whole thing or pay too much attention because I don't have one but I'll try to remember to read it for you.
Old 11-30-2007, 04:57 AM
madmodelman
I think it's just somebody scared of new technology, I was apprehensive at first, it's a bit weird. I race Gas powerboats Nationally and it's a very alien feeling switching on to check out when other boats are racing but of course you can do it, with no problems.
Interestingly, that's how I got into Heli's, simply because the software was in the Tranny!
I have to say though, the FASST system is as solid as a rock.
Old 11-30-2007, 04:55 PM
BarracudaHockey
TRIM effects a FUNCTION, ie Aileron. (two servos in the case of ccpm)
Subtrim effects a SERVO, they are not the same thing and cant be used to center a particular servo to get correct ccpm geometry.
I've been around this block with folks showing up for help with 6ex's
Old 11-30-2007, 11:11 PM
oly_rcer
thx for all the great answers folks i ended up getting a dx7 and an ar 6100 setup now the fun part of programming starts
