Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
DX7 setting for my 450 SE V2, will they work?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 12-02-2007, 09:36 PM
zaboaa
Default DX7 setting for my 450 SE V2, will they work?
The basic set-up is spot on, swash level etc. Using several sources (Forums and Finless videos), here are my DX7 settings, can anyone see anything completely out of whack? (I'm a noob so i tried to tone it down a little in NORM, not to worried about ST's until I get better, but want toget there in the future):
Pitch Curves:
NORM: -2, 0, +6
ST1: -10, 0, +10
ST2 Same
EXP: ON all modes
Throttle Curvesall %0
L 1 2 3 H
NORM: 0 40 80 90 100
ST1 &2: 100 95 90 95 100
EXP: On all modes
D/R & EXP:
POS 0 POS 1
AIL +30%/ 100% +30/70%
ELEV +30%/100% +30 /70%
RUDD LIN/100% LIN/100%
AUTO D&R EXP:
NORM P-1
ST-1 P-0
ST-2 P-0
HOLD P-0
Throttle HOLD
Hold POS. -5%
SW: RUDD D/R
Old 12-03-2007, 12:16 AM
Cleared2Engage
Cleared2Engage's Avatar
Default RE: DX7 setting for my 450 SE V2, will they work?
Everything looks pretty good. Go fly and see how it feels for you, tweek to fit your flying style
Old 12-03-2007, 08:17 AM
TheBum
My only comment would be that you might want a steeper throttle curve at the bottom end of the Normal curve. If you get the heli in wind, you may need the extra throttle with the small amount of negative pitch provided by your pitch curve to bring the heli down.
Old 12-03-2007, 08:29 AM
hennesseylord
my advice if you are going over 10ft is to use st1, makes the heli a lot more stable bring it down and gets you into a good habbit of going from norm to st then norm to land. even if you are just hovering around its good to use st1 because its more responsive and when you starting to go high, when you come back down you really have to lower the headspeed to bring it back down in norm, that means you loose responsiveness.
Old 12-03-2007, 10:05 AM
zaboaa
thanx for the comments, I'm kinda scared to go ST1, the first time I did it (I think I didn't have a good basic set-up) I smashed it pretty hard (pancake). Probable did it too close to the ground, LOL...
