Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 T-REX450SE V2 Motor Pinion Position >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-13-2008, 01:06 PM
Default T-REX450SE V2 Motor Pinion Position
Hey, Guys.
I'm 99% done, but doing final tweaking.
I have the 12T motor pinion height on the motor shaft positioned to where the top of the pinion is pretty much flush with the top of the Blue Main Gear. I have just the tiniest visible amount of end play (guessing maybe .2mm) on the heli's main shaft; just enough not to bind, I guess.
Mesh I have I would say maybe 95% as there is, again, just the tiniest amount of backlash.
I noticed the motor pinion flares at the bottom, and I had the pinion set too high as the bottom of the blue gear looked like it was chafing just the tiniest amount; hinted by the off color I attribute to powdering.
Do I have it adjusted correctly now?
Do You all run two strips of paper between them to adjust the mesh?
What is Your method?
Thanks, again.
Gary
Old 01-13-2008, 01:20 PM
madmodelman's Avatar
Default RE: T-REX450SE V2 Motor Pinion Position
Gary, why don't you look at Finless's videos, he covers all the things you are asking in all his 450 vids, very useful.
Old 01-13-2008, 01:33 PM
I must have missed that one.
Thanks!
Gary
Old 01-13-2008, 02:52 PM
BryFlyGuy67's Avatar
Gary,
Don't sweat it! You are probably good right the way you are!
Cut a small slice of regular printing paper. Feed that into your gear mesh. The "results" should be an accordian-like strip with no torn spots.
Adjust as necessary. On my setup, I didn't have to adjust a thing. It was perfect right from the get-go.
Old 01-13-2008, 02:55 PM
Hey Gary,
I agree about watching the finless videos. They are invaluable resources that cover EVERYTHING we'd ever need to know about our SE V2.
You are close man!
I finally finished mine up yesterday and have hovered about 4 battery packs now. I'm psyched to start nose in but nervous as hell....don't want to wreck my new build.....yet!
Hey, for some reason I can't seem to PM you. I've answered one of yours and sent 3 others...but my sent box still says 0 sent....have you received any from me?
Good luck bro!
John
Old 01-16-2008, 11:02 AM
where do i find finless videos for the trex?
Old 01-16-2008, 11:08 AM
http://www.helifreak.com/showthread.php?t=11373
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
