Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Castle Creations 35A Settings?? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-14-2008, 07:53 PM
BryFlyGuy67's Avatar
Default Castle Creations 35A Settings??
Here are screen shots from my CastleLink software. If you are familiar with this ESC and programming interface, please let me know if anything looks wrong. Thanks!
This is for a TREX V2 with a MedUSA 028-032-3400 motor, CC35A ESC, Castlelink, Cyclic: HS65MG Taiil: Gy410 & 9650. DX7 Tx. AR6100 Rx.
ID:	851330   Click image for larger version
ID:	851331   Click image for larger version
ID:	851332   Click image for larger version
Old 01-14-2008, 08:00 PM
soneebee's Avatar
Default RE: Castle Creations 35A Settings??
can you post the advance tab? there seem to be nothing wrong with the first page....
for the medusa.. you can run the ESC in governor mode.. it will be more reliable
Old 01-14-2008, 09:45 PM
That is the third screen, despite what it may look like.
Old 01-15-2008, 03:19 PM
ORIGINAL: soneebee
How does the rest look? How do I setup governor mode on this? Is governernor mode more reliable than running a flat throttle curve on the DX7?
Old 01-15-2008, 06:00 PM
soneebee's Avatar
The medusa runs nicely on gov mode.... You can set the Gov to Governor High... but you need to know how to get the correct head speed and to setup governor...
its kinda long procedure since you have to get the head speed correctly not just setting on the radio.. but there is some mechanical settting involved.. like the correct pinion size at 75% motor capacity to get XXXX head speed....
you can try to download bob white's video on the setup for gov mode on CC ESC's.. It works great and the power of this medusa motor is awesome.. almost no bogging on hard climbouts.... good for 3D flights
Old 01-15-2008, 06:21 PM
ORIGINAL: soneebee
Hmm. Is that available along with the rest of Finless' videos at HealiFreak?
Old 01-16-2008, 07:08 AM
soneebee's Avatar
yup.. its part of his videos... its under I think castle creations 60A ESC.. it has the same procedure though...
Old 01-16-2008, 04:24 PM
Hmm. Governor mode sounds like it will be important later, when I get better, but for now, I am just going to use the throttle curves on the DX7 to change my HS.
Thanks for all of the replies!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
